Possible engine damage
2012 CHEVROLET SILVERADO
96,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
REWARD5
Jiffy Lube drained engine oil(6qts) and for some reason put 2 qts of auto Trans fluid in motor. Drove 106 miles then motor started knocking bad. They flushed engine, replaced filter & added 6 qts of correct oil. Slight intermittent knock. When I get to shop knocking stops. Up till this always serviced at dealer. Jiffy Lube gave me a 2 yr/ 24k mile warranty on motor. What damage is done and is this warranty ok? Never had any issue w/ truck. Expecting long life but concerned life if motor is greatly reduced.
Jan 22, 2016 at 11:04 AM
WRENCHTECH
  • 20,761 POSTS
You definitely did some damage. I would expect that you took off 50% or more of that engines potential life.
Jan 22, 2016 at 11:10 AM
PACO8224
  • 117 POSTS
The warranty seems reasonable, it is plenty of miles if there were any damage to vehicle made it will definitely occur before then. It had just thinned your oil making the engine knock. How many miles have you drove it since they changed the oil again
Jan 22, 2016 at 11:14 AM
REWARD5
Sorry. Should have been more clear. They ONLY out 2 qts of auto trans fluid. No motor oil. Employee came to location and had to add 4 qts oil to get to full mark. At their shop they told me there was only 2 qts of auto Trans oil put in.
Jan 22, 2016 at 11:17 AM
WRENCHTECH
  • 20,761 POSTS
Nothing in his question states there was anything but 2 quarts of trans fluid in the crankcase. There is no question that life was taken off those bearings. 2 years isn't going to be enough to reflect the lost potential in that engine.
Jan 22, 2016 at 11:18 AM
PACO8224
  • 117 POSTS
I must of read the question wrong regarding the 2 quarts of trans. In the engine
Jan 22, 2016 at 12:40 PM
REWARD5
Thanks. Jiffy World will be replacing my motor now.
Jan 27, 2016 at 10:52 PM
WRENCHTECH
  • 20,761 POSTS
Well, that's good news. Persistence paid off.
Jan 27, 2016 at 11:05 PM
