1988 Chevy Silverado wont start
SUPRSLUGER911
  • 1988 CHEVROLET SILVERADO
  • V8
  • 167,000 MILES
My truck was running fine yesterday when I parked it in the driveway. But when I woke up this morning it cranked started up, then died. I tried to crank it again and it would not start up. It sounds like it is trying to start it just will not "catch." Ive replaced the starter module located on the distibutor because this was the problem last time. But now there is still no luck. This is my daily driver and my only form of transportation to and from work. Any help would be appreciated.
thank you.
Tuesday, December 16th, 2008 AT 1:24 PM
DOYLE48433
Sounds to me like its your fuel pump, when you turn your key tothe on position, not start though, you should hear the fuel pump kick on. If you dont then its prolly the pump. Or you just might be out of gas.
Thursday, September 3rd, 2020 AT 10:03 AM
SCOTTISH
  • 16 POSTS
Im having the same problem I just did my fuel pump and its still doing the same thing if you find out what it is let me know and I will do the same mine is a 93 2500
