1988 Chevy Silverado driver's side door
1988 CHEVROLET SILVERADO
ZEPH
Interior problem
The driver's side door is hooped. How do we get the hook on the bottom inside to catch? The space is small and hard to see to do it. The rod down to the catch is about 8" long.
Aug 10, 2008 at 10:25 AM
MERLIN2021
  • 17,250 POSTS
Hooped? I'm lost on this one what does this mean? Are you asking about the control rods inside the door? Or the stiker on the post? or the latch for the door?
Aug 10, 2008 at 10:32 AM
ZEPH
Hi Merlin
Sorry I wasn't very detailed; my stepdad's driver's door does open from the inside. But it will not open from the outside however.
He said the control rod/wire is about the same size as a #9 wire. It has a hook on the end. It goes down to the latch on the outside edge of the door (black plastic latch which isn't broken), but he said that the control rod veers off into a square, then back. The window guide is behind it and is getting in the way of hooking the rod back up inside. A local mechanic told my stepdad that a special tool is needed to do this in order to get to it and do it. My stepdad would like to know if there's a way to do it without having to buy the special tool or take it in to a shop.
Aug 10, 2008 at 11:57 AM
MERLIN2021
  • 17,250 POSTS
I havent heard of a special tool for this, but that doesnt mean there isnt one! When control rods pop off, either the retaining clip broke, or it too popped off. you need to get it into the hole, and lock in the retainer. Autozone rents most tools you need, and in the end it's free.
Aug 10, 2008 at 7:38 PM
