1994 Chevy S-10 Rough Running
MARKSS10
I have a 1994 Chevy S10 pickup, 4.3L engine. And I put some slick 50 engine/fuel cleaner in it and filled up the tank with gas. Every thing was great, until I backed up over a bump and then shifted to drive. When I did that, the truck jerked. And now, it's running rough.
When I go down the street, it's hard to pull gas. The truck hesitates a bit. I'm not sure if I cracked a valve or maybe something else.
Where can I start first?
Jun 4, 2007 at 8:52 AM
SERVICE WRITER
  • 9,123 POSTS
Maybe you did nothing. Check the fuel pressure for starters.
Jun 4, 2007 at 10:26 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_ya_think_1.jpg
Jun 9, 2007 at 2:11 PM
Suggested Repair
Start by checking fuel pressure. Do not assume a cracked valve until fuel delivery is verified.
Conversation Summary
The owner of a 1994 Chevy S-10 4.3L added Slick 50 engine/fuel cleaner, filled the tank, then felt a jerk after backing over a bump and shifting into drive. The truck now runs rough, hesitates, and is hard to accelerate. The owner suspects a cracked valve. The expert said the cleaner may not be the cause and recommended checking fuel pressure first.
