Here's where it gets really interesting for me. My A/C has not been running on the truck for quite a while due to an assumption I made (based on bad advice) that there was a major problem with the system. I decided a couple of weeks ago to try charging the system and it worked! Now I have wonderfully refreshing air!
The greatest result is I have found that when the A/C is running, the engine runs very smoothly with none of the issues I mentioned. It doesn't sputter at speed, die at stops, and the service engine light has not come on once. Can you give me some idea as to what could be causing the problem? I have been told it might be a problem with the A/C sensor, but have never even heard of it. Thanks for the help!
Thursday, August 20th, 2009 AT 4:59 PM
