Trans has problem shiffting
POTTER87
  • CHEVROLET S-10
I have a 1991 chevy s10, 4.3L and auto trans(700R4). The engine has around 50,000 miles on it because it was completely rebuilt. The odometer says 202,000 miles. Im not sure how many miles are on the trans. It shifts into all gears smooth but when shifting from 4th to overdrive, it takes a long time. It does'nt shift into OD till around 55 - 60 MPH. Sometimes if I left off the gas a little bit it will shift but not all the time. I changed the fluid and filter about 15,000 mi. Ago. A few years ago it would'nt shift out of first gear, until I went down a big hill then it shifted fine. That is when I changed the fluid and filter. I have not done any modifications to it.
Thanks for the help
Monday, August 13th, 2007 AT 11:58 PM
2CARPRO JACK
  • 11,533 POSTS
There is an adjustment on the TV (throttle valve) cable on your truck up at the throttle body. Try taking a small amount of tension out of it and try it.
Tuesday, August 14th, 2007 AT 8:09 AM
