1994 Chevy S-10 Temp Gauge Not Working
TORGANC
94 Chevy S 10 2.2L. Along with my idle/transmission problem, I also have a problem with the temp gage. I put a new sensor in , but gage still does not work. Any ideas?
Apr 10, 2007 at 12:36 PM
BOOTDOG
  • 665 POSTS
check for a broken wire, if thats ok then i suspect the gauge.
Apr 10, 2007 at 12:57 PM
TORGANC
thank you for the tip. should I try jumping a new wire from dash to gage?
Apr 10, 2007 at 1:04 PM
BOOTDOG
  • 665 POSTS
the gauge is in the dash. from the temp sensor trace the wire back to make sure it's not broken anywhere.if not replace the gauge.
Apr 10, 2007 at 1:13 PM
Suggested Repair
Trace the wire from the temperature sensor back to the dash and check for breaks. If the wiring is intact, replace the temperature gauge in the dash.
Conversation Summary
The owner of a 1994 Chevy S-10 2.2L replaced the temperature sensor, but the gauge still does not work. The expert advised tracing the sensor wire for a break and replacing the gauge if the wire is good.
