1994 Chevy S10 Oil Gauge Pegs
PRSCCRPLAYA21
i have just switched engines in my 1994 chevy s10 and i have one plug i cant find, im pretty sure it goes to the oil sensor because everytime that i turn it on the oil pressure gauges instally shoots over 180 but it runs fine and sounds great i was wondering if someone could help me out and tell me where i have to plus it in, i have no idea where it goes ive spent about 4 hours looking and there no outlet on the oil pan for it.
Apr 8, 2006 at 12:17 PM
KENB79764
  • 52 POSTS
the oil sensor is normally about halfway up the block, usually under the intake. best way to find it is with a mirror and flashlight.
Apr 9, 2006 at 1:29 AM
Suggested Repair
Locate the oil pressure sensor about halfway up the engine block, typically under the intake manifold, and connect the unused plug there. Use a mirror and flashlight to find the port; it is not on the oil pan.
Conversation Summary
After an engine swap in a 1994 Chevy S10, the owner cannot find where one plug connects and suspects it is the oil sensor because the oil pressure gauge immediately jumps past 180, though the engine runs and sounds fine. No fitting was found on the oil pan. The expert says the sensor is normally about halfway up the block, usually under the intake, and is easiest to locate with a mirror and flashlight.
