s10 will not run
WILLIAM BELL
i have a 1991 s10 with a 2.5 lit. the truck was running it just shut off one day while i was driving it , it has 183,000 miles on it 5 speed, it will crank over but not pumping gas, i put an elecrict fulepump on it but it will not spray gas into the injector and start, also when it was running, after you was driving it for awhile the check engine light would come on and the truck started jumping when you tryed to pull out, like the cluch was not engaged, but if you shut it off and restarted it it would run fine for awhile, then state doin it again, guys im running out of ideas can someone please help me thank you if you have any ideas. :lol:
Nov 15, 2007 at 12:40 AM
  • 75,988 POSTS
Check the fuel pressure and comeback with the readings.
When you turn key to On position do you hear the fuel pump? If not disconnect the fuel pump connector and check for battery voltage at Tan and White wire.
Nov 15, 2007 at 3:11 AM
