2010 Chevrolet S-10 High Idle
FARM S10
My truck will only run at an extremely fast idle. Mileage is up around 200 thousand. Runs good but presently not driveable due to this super fast idle. Have had a look at the carb but see no obvious defects. Any advise would be a great help. Thanks.
Dave
Jun 1, 2007 at 4:50 AM
RANGLER
Been there, paid for that..here is your answer for free
Possible leaking intake manifold gasket- just below the
throttle body..idle your truck and carefully spray some
carb cleaner around the gasket area..if it is leaking,,the
fluid will temporarily "fill" the gap and the idle will drop
momentarily..then once sucked in will will resume fast
idle.
Also possible missing tension spring on the linkage
My '88 GMC S15 had both problems..one after the other
new spring..and new intake manifold gasket..all good.
This guide can help
https://www.2carpros.com/articles/engine-idles-too-high
Jun 19, 2007 at 5:25 AM
WRENCHTECH
  • 20,758 POSTS
First eliminate all vacuum or air leaks in the system. You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Aug 21, 2019 at 11:37 AM (Merged)
  • 75,988 POSTS
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor. Also the throttle plate could be binding in its bore and kinked accelerator cable, coolant temperature sensor might not be operating properly misleading the computer that the engine is still cold and computer throwing fuel at it raising the idle speed.
TRANSAM350
Car idles around 2000 rpm constantly in nuetral and around 1300 in drive. Have replaced almost every sensor such as TPS, MAF, MAP sensor, ignition control module, IAC, and just put a new throttle body and gasket on with no luck. Doesnt start right away. When turning engine over it idles normal for about 15 seconds then jumps up to around 2000. Sometimes will randomly jump down to around 300 or so and want to die only to go back up to 2000 again the next day. Any ideas?
Nov 22, 2019 at 2:20 AM (Merged)
JOHNNYT73
  • 924 POSTS
I would next check for a vacuum leak. Follow all vacuum lines and inspect for breaks or cracks. Look near the corner of driverside corner of firewall for the little vacuum lines to be rotted or cracked.
CHIP
2001 S-10 4WD Sometime when you stop it idles up and down and dies, not always! Sometime it shakes even at hiway speeds, it even died yesterday going 70 mph. It always starts right back up and if I give it a little gas seems to be ok for a while? Suggestions?
SAMTHEMAN
  • 31 POSTS
Are there any trouble codes, if there are get a scanner tool(autozone lets you use theirs for free!) and read the codes.
If not, this sounds either like a bad Throttle Position Sensor or a Idle Air Control Valve.
Before doing that, check your air filter, it could be dirty, as well as your MAF sensor(Mass Air Flow). To clean your MAF sensor do a quick google search. It is easy and simple, probably only ten minutes of your time.
Also, if you are good with cars then try testing the plug wires. Set the multimeter to ohms and read it. It is usually 3-5k ohms per foot. If there is not resistance showing up then it is definitly a bad plug wire. While you do that check your plugs.
If none of these seem to help, I recommend calling local mechanics to see if they can diagnose what is wrong with your car. Most places will do it for free if they dont use any equipment. Others may charge $75 an hour for labor.
Hope this Helps!
HMAC300
  • 48,601 POSTS
do the enginescan thing if your service engine light is on. take your air duct off and take choke cleaner and spray the throttle plate on both sides, they getgummed up with oil and stick. check for vacuum leaks andcheck your fuel pressure it shold be 60-66psi. if it's low and you change the fuel pump change th filter as well.
HOWARD1984
i have a 2000 s10 with a 4cyl in it at first it was reved up real high like at 4500 rpms by it self so i changed the throttle position sensor and and the other sensor that has a spring for the vacum and the vacum line that goes on top of the throttle body now its just reving up and down by itself could some one please tell me what the problomn may be thank you
  • 75,988 POSTS
The idle air control valve could be sticking try cleaning it out and see what happens. Also clean out the throttle bore plate
BIGAL0420
Very high idle around 4000 rpm is this a vacuum line?
Nov 22, 2019 at 2:21 AM (Merged)
JDL
  • 16,098 POSTS
Yes, it might be a vacuum issue? Make sure the throttle valve is closed. Clean the throttle-body check the iac.
HMAC300
  • 48,601 POSTS
if this is a throttle body unit they tend to blow the gasket under the unit. a can of choke cleaner sprayed around the bottom will tell. if the idle changes up or down you've found the leak. also the hose going to map sensor gets soft and sucks together make sure that is in good shape.
HMAC300
  • 48,601 POSTS
i screwed up ith the answer. these have to be checked to see if the injector harness is connected correctly as they will lose contact. also the injector lines inside the intake crack and can leak. it may be that as well.
JENNY1975
Check map sensor and electrical connection/pigtail for burnt or broken wires. Map sensor causes very high idle, shifting problems stalling etc.. sends false codes also
  • 55,851 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Suggested Repair
Check for unmetered air: with the engine idling, carefully spray carburetor or choke cleaner around the intake manifold and throttle-body gasket and vacuum fittings; a brief idle change indicates a leak. Inspect vacuum lines, the MAP sensor hose and connector, and throttle linkage spring. Confirm the throttle plate closes fully, clean the throttle bore and idle air control valve, and recheck idle.
Conversation Summary
The owner of a 2010 Chevrolet S-10 reports an extremely high idle that makes the truck undriveable, with no obvious carburetor defect and about 200,000 miles. Replies point to vacuum leaks, a leaking intake or throttle-body gasket, a missing linkage spring, a sticking idle air control valve, a dirty throttle plate, and MAP sensor or hose problems. Later posts describe similar high or unstable idle on other S-10 trucks after sensor and throttle-body work, and experts again recommend vacuum-leak checks, throttle and IAC cleaning, and verifying related connections and fuel pressure.
