S10 Headlights problem
MC1815
Hey I have a 1996 Chevy S10 pickup 4.3L V6 AT 190000km and I have been having troubles with my headlights. After awhile of driving at night my headlights will start clicking on and off to my DTR lights. The clicking noise is coming form within the glove compartment where the relays are so I replaced the headlight relay but that didn't fix the problem. I have also been searching for corroded wires and ground but I havn't had any luck yet. I was also thinking it could be the circuit breaker for the headlights, and I was just wondering where the location for that circuit breaker is or if that could even be the problem? Thanks
Sep 10, 2007 at 12:46 PM
FENDERDENT
Replace your headlight switch!! I had the same identical problem and the switch replacement cured it. It's not too hard to replace the switch, just remove the two screws ay the top of the instrument cluster (the rest of the plastic is held in by push clips) and carefully pull on the decorative plastic that holds the light switch and the perimeter that continues around the dash. When you proceed to pull the switch out of it's mount, be very, very careful not to break the plastic clips that hold it in. Look at everything very carefully and have patience. The switch is $20-$25 at your local parts store. The dealer will charge about $75 for the same switch.
Dec 17, 2012 at 5:22 PM
