Blower not blowing air through vents.
2010 CHEVROLET S-10
BIGHOGLK
Hi, I have a 1995 2.2 four cylinder in it. It has A/C on it. I turn the air or heater on and it just blows and does not put out much air even on higher setting.
I have read that it coud be a vacuum line or something in the dash. Could you be more specific on the vacuum line problem. Is it a small 1/4 inch line like on the firewall, or do I have to tear the whole dash apart? The 3/4" line has not leaks on the blower itself.
Thanks
May 14, 2007 at 1:43 PM
MCFERRANCE
  • 100 POSTS
Is the air blowing out the windshield defroster?
May 22, 2007 at 1:06 PM
EDC
I have the same problem on a 1997 S-10. AC blows through defrost vents only. Need help please.
Jun 28, 2007 at 12:17 PM
MCFERRANCE
  • 100 POSTS
You most likely have a broken or disconnected vacuum line to the servos under the dash that control the air flow. On the older S-10's there is one near the gas pedal that may get disconnected. Also, check where the vacuum line goes through the firewall.
On my 1988 S-10, the plastic clip was broke that holds the servo rod to the door that it actuates. So if all the lines are okay, check the servos.
Jun 28, 2007 at 12:23 PM
ELLIOTTCOX
I have a 2002 S-10 with the same problem. The air seems to blow okay for the first ten minutes of a drive, after that I get a lot of noise from the blower, but minimal air.
Sep 16, 2007 at 1:21 PM
