1994 Chevrolet S-10 White Smoke
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
Suggested Repair
Confirm a head gasket leak with a block test first, or use a gas analyzer to check for hydrocarbons at the radiator fill neck. Do not pressure-test the cooling system if a head gasket leak is already suspected, because coolant can enter the cylinders and cause hydrolock or connecting-rod damage if the engine is cranked. Repair the head gasket before pressure testing.
Conversation Summary
The owner of a 1994 Chevrolet S-10 Blazer with a 4.3 Vortec reports thick white exhaust smoke after replacing the CPI and was told it could be a head gasket or intake gasket. The expert recommends a block test first or a hydrocarbon sniff test at the radiator neck to confirm combustion gases in the cooling system, and warns against pressure testing until a leaking head gasket is repaired.
