1999 Chevrolet S-10 Engine Sputtering
CONCIOUS1
It just started today. I drive a 1999 Chevy s10 pick up with a v6 engine. I stopped at a red light and it stalled on me. It started right back up, but from there out it felt like the engine was jumping to stay alive. When the AC was on it was even worse. My belt seems to be tight enough. What are some things it could definitly be?
Oct 9, 2007 at 8:21 AM
CHEVY22
  • 1,375 POSTS
if the check engine light is not on go for a major tune up if it hasnt been done in a while , cap , tor, wires and plugs and use gm parts, they are a bit more in price but work perfect ,oh and a fuel filter
if the light is on have it checked first
jim
Oct 10, 2007 at 1:44 PM
Suggested Repair
If the check engine light is off, do a major tune-up with GM cap, rotor, wires, and plugs, and replace the fuel filter. If the light is on, have the codes checked first.
Conversation Summary
The owner of a 1999 Chevrolet S-10 V6 said the engine stalled at a light, then sputtered and felt like it was struggling to stay running, worse with the AC on. Belt tension seemed fine. The expert advised a major tune-up with GM ignition parts and a fuel filter if the check engine light is off, or a code check first if the light is on.
