I've got a '92 S10 with the 4.3L engine and 120k miles. A couple days ago the hydrolic brake wore thru and the fluid leaked out. After repairing the line, I haven't been able to get pressure built up at the clutch pedal. I've bled the system but not been able go get any noticable pressure at the slave cylinder. If I pump the pedal rapidly in short strokes, I hear the sound of moving fluid in a cylinder mounted on the fire wall that is about an inch dia. and 3 inches long. What is this cylinder and do you have any idea what may be wrong.
Jun 28, 2007 at 1:05 PM
