1999 Chevrolet S-10 Clutch Engages Too Soon
HEEEEYHOWDY
chevy 99' s10 2.2L 5 speed roughly 110,000 miles, when i push the clutch in all the way to the floor and let off the slightest little bit my truck takes off. theres no pressure on the pedal until it gets about 3 or 4 inches from the floor. iv checked the clutch fluid its full, the guy i bought the truck from says he has replaced the slave cylinder.
Oct 17, 2007 at 6:00 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it may be time to replace it.Be sure all components are done at that time(pilot bearing, throw-out bearing, disc and pressure plate)
Oct 18, 2007 at 7:19 AM
Suggested Repair
Replace the clutch assembly, including the disc, pressure plate, pilot bearing, and throw-out bearing. Fluid is full and the slave cylinder was reportedly already replaced, so the high engagement point points to a worn clutch.
Conversation Summary
The owner of a 1999 Chevrolet S-10 2.2L five-speed with about 110,000 miles says the truck moves as soon as the clutch pedal is released slightly from the floor, with little pedal pressure until a few inches off the floor. Clutch fluid is full, and the seller said the slave cylinder was replaced. The expert recommends replacing the clutch and related parts at the same time: pilot bearing, throw-out bearing, disc, and pressure plate.
