1998 Chevrolet S-10 Dies After Start
I'd have to make sure the battery has a full charge and battery connections all clean and tight. Then check your charging system. Some of the national brand auto stores will probably check this for free.
If you have the 4.3L engine, that fuel pressure spec on start-up is critical, 60--66 psi.
Your oil pressure spec says 18 psi @ 2000 rpms. Your oil pressure can go up and down with rpms.
Suggested Repair
Confirm the battery is fully charged and that the battery connections are clean and tight, then have the charging system tested. If the truck has a 4.3L engine, verify startup fuel pressure is 60-66 psi. Compare oil pressure readings with the spec of about 18 psi at 2000 rpm, noting that pressure can vary with engine speed.
Conversation Summary
The owner of a 1998 Chevrolet S-10 says the truck starts, shuts off after about five minutes, and then cranks as if the battery is weak, suspecting the charging system or a ground. The oil pressure gauge also malfunctions. The expert advises confirming a full battery charge and clean, tight connections, then testing the charging system. For a 4.3L, startup fuel pressure should be 60-66 psi. Oil pressure should be about 18 psi at 2000 rpm and can vary with engine speed.
