Chevy s10 blazer
LOST4EVA0323
Chevy s10 blazer V6 4.3, 160000 miles. I put a new fuel pump in it and I hear it kick on when I turn the key. It turns over but it still wont start. I tried the trick of spraying starter fluid into the intake to give it a jump and it worked, but when the fluid burns off the truck turns off.
May 17, 2007 at 5:50 AM
JDL
  • 16,098 POSTS
Sorry for the late reply.
I'd have to check proper fuel pressure and fuel injector pulse engine cranking. Two things I can think of that would keep the injector from pulsing ground, one is the security system where applicable, or no rpm signal. You can also check voltage at injector, key on.
Mar 16, 2015 at 6:52 AM
