chevy s 10 1985
STARVEN_MARVIN664
i have a chevy s 10 1985 long bed fleetside 2.8 v6 manual w/ 230,000 miles. i recently replaced my carrier bearing due to the rubbing noise it was making when the clutch was pressed. it ran fine for about three weeks, but now it makes a noise similar to the grinding of another bearing. the noise seems to be coming from directly below the cab. when the noise started up it was originally a loud chirping. the chirping has stopped and has been replaced with a rubbing sound. what should i check? any help would be appreciated
Jun 4, 2006 at 11:32 AM
JFALCON
I beleive I have the same problem. Except my truck won't move at all. It's the same truck 85 s10 longbox 2.8 v6. When the clutch is in it's quiet and fine when I let it out there's a horrible grinding noise from below the cab and the truck doesn't move. I changed the transmission and it worked great for a week and then the same thing happend again. It sounds like a similar problem but I was wondering if yours moves at all or if it's only noisy?
Jun 7, 2007 at 12:21 PM
