Truck won't start. Starter spins engine, spark is there, injectors fire 1 time on fuel pump prime. Ign. Control mod in distr. Cap tested good at local shop. 12v recv'd at injector plugs. NOID light test, works once, then failed? Bypass Ign Ctrl mod, 12v to purple wire on ICM, causes ECM to pulse injectors. Fuel pump tested, working within spec @ 11psi. Changed fuel filter & Rebuilt fuel press reg. Tested fuel pump relay, found good. Tested pickup on distr. Found 1500 Ohm resistance to body grnd, infinite resistance across terminals. HELP.I'm at wits end. What else would make this baby turn over, but not allow the fuel to be shot in to get her running? ALSO. ECM reports error code 12, all OK.
SPONSORED LINKS
Sunday, July 8th, 2007 AT 12:45 PM
