Starter motor replacement and location?
CODY JONES1
  • 1994 CHEVROLET S-10
  • 6 CYL
  • 97,000 MILES
How do I remove and install the starter
Wednesday, November 25th, 2020 AT 5:41 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Remove the negative(-) battery cable, then remove the wires at the starter, remove the two bolts holding the starter, be careful the starter is HEAVY! use caution removing the last bolt. Install is the reverse of the proceedure!
https://www.2carpros.com/forum/automotive_pictures/62217_Starter_2.jpg
XXXX1234
  • 6 CYL
  • 4WD
  • 199,550 MILES
I just replaced my starter and when I started my truck the new starter that I just installed wouldnt turn off, so whats the problem?
Wednesday, November 25th, 2020 AT 5:42 PM (Merged)
JDL
  • 16,098 POSTS
Hi, the S terminal at the starter solenoid should not be hot, except with the key in the start position. When you release the key, it springs back to the run position and the S terminal shouldn't be hot?
If no voltage at S terminal, usually purple wire, engine running, the pinion gear may be hung up on the flywheel. Does your starter use shims? With eveything turned off, remove flywheel dust cover, where applicable, see if pinion gear is still engaged to the flywheel?
