2003 Chevy S-10 Starter problems
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
THORNN01
I have the 4.3L 6 cylinder in my 03 S-10 pick-up. I have been having problems with starting it. Many times when the truck has been sitting for several hours, it will not start. I turn the key and hear a click behind the instrument cluster, but nothing happens. The lights don't dim, the starter doesn't click, nothing. I turn the key several more times and eventually it starts. It has started on the 1st turn, the 5th, the 75th. It has yet to happen if the truck has been running recently. Weather also seems to have no effect on when and if it will start. I have changed out relays so that isn't the issue. I've had the battery checked and its good. To get at the starter my manual says I have to remove part of the exhaust, so I've been delaying that since I don't have the tools to do it.
Any ideas? I don't know how or where to use a jumper to see if its the ignition swith itself.
Jun 27, 2008 at 7:31 AM
DOCFIXIT
  • 18,828 POSTS
Take a test light attach to solonoid wire on the starter little#12 wire. When it acts up if light does not come on ign switch if light comes on solonoid.
Good luck
Jun 27, 2008 at 8:02 AM
  • 75,988 POSTS
Check the crank fuse 10amp if okay-have helper hold key at start position and look for power at the purple wire on the starter solenoid, Power there -replace the starter-No power backtrack it to the starter relay then park/neutral position switch, then to the ignition switch
Good Luck
Jun 27, 2008 at 8:14 AM
