just bought truck so i do not know much about the history. when i bought it , it had a blown head gasket. i had it towed to my house. i replaced both head gaskets and all the rest of the gaskets above the heads. got everything put back together, turn the key, and does not even get a click. i checked for power at the #30, #87, #85 terminals of my starter relay. i have 12 volts at these terminals. what i do not have is 12 volts in the start position, when i jump the #85, and #86 terminals of my starter relay. i took the cover off off the relay, and when its plugged in, i can close the contacts manually, and the engine will crank over. i can even get it to run if i prime it first. i checked for 12 volts at the crank fuse, okay. i checked for 12 volts at the purple wire at the park/neutral switch in the start position, okay. i manually jumped the purple to the purple with white stripe wires at the park/neutral switch, nothing happens. i checked for continuity on the purple with white stripe wire from the park/neutral switch to the #87 terminal on the starter relay, okay. that is where i am at now. what do i check next ? should the #86 terminal be a ground? i believe it is opened. i saw a step by step method on here for checking the circuit. i did that and it brought me to where i am now, lost.
Sep 2, 2016 at 5:39 AM
