Engine Cooling problem
2003 Chevy S-10 6 cyl Two Wheel Drive Manual 110k miles
I recently flushed (store bought cleaner sytem) the coolant, radiator, and changed the thermostat. After a week the truck started to overheat (220-260 degree fluctuations). I assumed air had built up in the system ; however, I have tried running the engine with the radiator cap off until the thermostat opened and even running with the cap on but not locked. I could not locate any "bleed" pressure release points on the coolant system. Is there anything I can do?
Jesse
TN
Jesse
TN
Oct 1, 2009 at 7:07 AM
