2003 Chevy S-10 Engine howling and reduced performance
2003 CHEVROLET S-10
81,000 MILES • 4 CYL • 2WD • MANUAL
MAINEAK99
S10 started howling loudly, sound gets louder as the engine speed increases. Problem started while driving without overheating, warning lights or loss of oil pressure. Problem occurred once previously but, the engine returned to normal after a few hours of sitting. Appreciate any help...
Apr 22, 2009 at 8:45 AM
  • 110,244 POSTS
Does the sound seem to be metallic or does it sound more like wind?
May 2, 2009 at 7:38 AM
MAINEAK99
Does not sound mechanical more like wind. Like the fan is movig a whole lot more air or something like that.
May 2, 2009 at 9:49 AM
  • 110,244 POSTS
I need you to open the hood with the engine OFF. Try to turn the fan that is attached to the waterpump and run by the serp belt. If it is hard to move, the fan clutch is bad. Do this when the engine is cold.
Let me know what you find.
May 3, 2009 at 4:08 AM
MAINEAK99
Yes, it is very difficult to move.
May 3, 2009 at 5:15 AM
  • 110,244 POSTS
If you have a fan clutch, and I think you do, chances are the clutch is bad. Because I am not there to see it, I can't be 100% sure that it has the clutch fan (some do and others don't), unless you can take a picture of it and upload it to me. Otherwise, you will need to ask a mechanic.
May 3, 2009 at 11:35 AM
MAINEAK99
Thank you for the info, I will start with the fan clutch. I have also had a Ford F150 do the same thing when the air tube on top of the catalytic converter rusted through. So I am going to chaeck to see if the chevy has a similar setup.
Thanks again for your repiles!
Mike Harvill
May 4, 2009 at 1:41 AM
  • 110,244 POSTS
May 4, 2009 at 3:22 AM
