2002 Chevrolet S-10 Hard Cold Start
5yrs has passed, when was the last tune-up?
Normally a cold starting problems are related to fuel. Lets recheck the fuel pressure with a gauge with and without the regulator
Or do this when it refuses to start check for spark-disconnect a sparkplug wire or 2 ground it to the engine while cranking it over-Do you have spark?
Suggested Repair
Check the coolant temperature sensor, clean the idle air control and EGR valves, and confirm tune-up history. Recheck fuel pressure with a gauge with and without the regulator, and verify spark during a no-start.
Conversation Summary
A 2002 Chevrolet S-10 2.2 is very hard or impossible to start in temperatures around 20 degrees and below, needing repeated cranking until it fires; it starts normally once warm unless it sits. The fuel pump runs, fuel pressure was reported good, and swapping the ECM did not help. The expert recommended checking the coolant temperature sensor, cleaning the IAC and EGR valves, confirming service history and check-engine-light behavior, retesting fuel pressure with and without the regulator, and checking for spark when it will not start.
