2002 Chevy S-10 warning lights all came on while moving/wen
144,500 MILES • 6 CYL • 2WD • AUTOMATIC
DENNIS MCDONALD
All warning lights came on and blinked off,tach was going to 0 and back up,speedometer was going up and back to 0. I stopped the truck and all the lights went off. When I started moving again all the lights came on and continued to blink off and on. I pulled off the road (home) and shut the engine off. Now I have no lights (headlights, interior lights, etc.) I can move the ignition key and make the radio come on (sometimes). Truck will not start, like a dead battery, but battery reads full 12 volts with a meter. Would an ignition switch cause all this? I've checked all fuses and wiring all looks good. Is there a computer chip I should be aware of? I'm really open to suggestions here.
Sep 24, 2008 at 3:25 PM
MERLIN2021
  • 17,250 POSTS
With all the lights flashing it sounds like a bad bulkhead connection, ceck all electrical connectors, check for bent and pushed out pins, if you have a DVOM, check for power at the fuse box.
Sep 25, 2008 at 9:27 AM
