you can crank it, it will run for about 2 seconds and die. And it will do this untill the abundent temp is around 40 degree's.
i have put new spider, injectors, battery, fuel filter, fuel regulator, temp sending unit. Spark plugs, wires, rotor, distrubitor, replaced vacum hoses, had the ECM checked, no codes. I had the dealer check the fuel pressure and they said that its fine. Im about ready to pull my hair out, someone please help!
SPONSORED LINKS
Wednesday, January 27th, 2010 AT 10:42 AM
