when I turn the key the fuel pump and lights come on but nothing else happens, I took the wire going from the coil to the distributor off and no spark came through it. Help me please
ok I got your message thank you for answering and I will make a donation as soon as my truck is fixed and my wedding day is over.
i have no spark going to the ignition module, which I replaced, and no spark to the coil. The starter tests good. The only thing that happens when I turn the key is the fuel pump comes on. My ecu is throwing code PO413, something about an secondary air control. Other than that it ran fine before I would not start. The oil looks good. The engine can be turned with a wrench so the engine isnt blow. The plugs are brand new acdelco platium, the distributor cap is new from napa and rotor. I am stumped.
SPONSORED LINKS
Monday, November 26th, 2007 AT 10:27 AM
