2001 Chevy S-10 oil pressure
DOUGLAS26
  • 2001 CHEVROLET S-10
  • 4 CYL
  • 47,000 MILES
My 2001 s-10 4cly runs fine but makes noise at idle after running for a while oil pressure at idle when warm falls to 20 and makes noise when cool at start-up it makes no noise oil at 60 at start up
Monday, May 26th, 2008 AT 12:03 PM
  • 31,937 POSTS
Hi there,
You may have a problem with the pressure dropping due to worn crank or cam shaft bearings, a faulty pump or pressure relief valve. I would do an engine service and have the pressure tested with a master gauge. Do this first.
Mark (mhpautos)
Monday, May 26th, 2008 AT 10:47 PM
