1994 Chevy S-10 clutch for A/C compressor not engaging
SAMIS10
  • 1994 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 176,000 MILES
Recently had r & r a/c hoses & mnifld set
evac & charged. Was blowing cold, no noises. About a month later, on the way home from work air was warm. Full of freon, but the clutch for the compressor not engaging. Any idea what I could check? Wires, fuseable link?
I greatly appreciate any ideas, or advice. Thanks Sani
Tuesday, August 3rd, 2010 AT 11:24 PM
Check and test the high and low pressures, magnetic clutch, pressure switch, AC relay and the HVAC control module.
Wednesday, August 4th, 2010 AT 1:11 AM
SAMIS10
Thank you so much, I will check all that you mentioned & reply. Greatly appreciate your help & time.
Thursday, August 5th, 2010 AT 1:22 AM
