2001 Chevy S-10 4 wheel drive problem
159,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAREDNB
When i put my truck into 4 hi and if the tires spin or i just drive it every 30 seconds or so the front tires make a noise as if the front tires are slipping.
So i decided to check the transfer case lubricant, when i drained it barely any fluid came out and what did looked like oil and its suppose to take transmission fluid.
Any idea on what i can do about it?
I was thinking about trying lucus oil but not sure if thats aloud to go in transfer case or should i try just draining it again?
Jan 14, 2009 at 3:29 AM
  • 110,248 POSTS
Hi:
If it was that low and dirty, refill it and run it for around a hundred miles or so. Then, drain it and refill it. It should be ok after that.
Let me know if this helps.
Jan 15, 2009 at 11:54 AM
JAREDNB
ill give that a try then ill let you know what happens, thanks.
Jan 16, 2009 at 1:18 AM
