The vehicle runs fine oil pressure is up for around five minutes until it warms up then oil pressure drops and it loses power I have changed the oil pump still the same please help.
Thursday, March 4th, 2010 AT 4:19 PM
HMAC300
MECHANIC
Loss of power can be several things, try a fuel filter first and air filter ifyou haven' treplaced it in a while Oil pump won't cause what you having. You might run a scan on it and look for vacuum leaks to cure this as well.
