2000 Chevy S-10 the clutch
2000 CHEVROLET S-10
LILDRUIDESS
Transmission problem
2000 Chevy S-10 4 cyl Two Wheel Drive Manual
can you please tell me and show me where to bleed my clutch? my manule does not show me where the thing is. Thanks
Jan 28, 2010 at 6:04 AM
MERLIN2021
  • 17,250 POSTS
1. Clean and remove reservoir cap. Top-off reservoir with NEW DOT 3 brake fluid. 2. Have assistant depress and hold clutch pedal. Open bleed screw located on left side of transmission to expel air. Close bleed screw and release clutch pedal. 3. Repeat procedure until all air is out of system. Check and refill reservoir as necessary during bleeding. After bleeding, pump clutch pedal several times. If clutch engagement is not satisfactory, repeat bleeding procedure. 4. If normal bleeding procedure is unsuccessful, remove reservoir cap. Pump pedal quickly for 30 seconds, and then stop to allow air to escape. Repeat procedure as necessary. CAUTION: Do not reuse fluid bled from system. Fluid may be aerated or contaminated. Ensure no air is drawn into clutch hydraulic system during bleeding procedure.
No diagram sorry...
Jan 28, 2010 at 6:56 AM
