2000 Chevy S-10 POWER STEERING
MEL PROCTOR
  • 2000 CHEVROLET S-10
  • 4 CYL
  • 76,000 MILES
Power steering works smoothly in one direction but not in the other. Mechanic replaced computer but it did not solve the problem. What else can we do?
Saturday, October 11th, 2008 AT 3:20 PM
JAMES W.
  • 2,394 POSTS
In the direction that it turns hard, does it turn just harder than normal or like there's no power assist at all. (Like motor isn't running.) Please advise.
Saturday, October 11th, 2008 AT 3:39 PM
MEL PROCTOR
WHEN YOU TURN TO THE RIGHT IT IS NORMAL. WHEN YOU TURN TO THE LEFT THE CAR SHAKES AND THE ENGINE TRYS TO DIE AS IF IT WERE NOT GETTING GAS.
Saturday, October 11th, 2008 AT 4:55 PM
JAMES W.
  • 2,394 POSTS
From the way you describe the problem, it sounds like the power steering sector itself. It's turning OK one way indicating the pump and pressure system are good. The other way the PS pressure wants to go into bypass because the PS sector won't accept the assist. Going into "bypass" is what is trying to stall the engine. I've done quite a bit of research on your problem and everything points to the sector.
Saturday, October 11th, 2008 AT 7:23 PM
