1999 Chevy S-10 wont start!
SKEETER7580
  • 1999 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 125,000 MILES
I parked my truck and the next day when I went out it wouldnt start. It cranks over good but thats it.
Sunday, November 9th, 2008 AT 12:34 PM
Do below to determine if its fuel or spark problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, November 9th, 2008 AT 1:51 PM
