1999 Chevy S-10 shakes
1999 CHEVROLET S-10
158,241 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNDEERE16
i went mudding and i got stuck and i had some one pull me out the put a rope and tied it under the body frame. and when the pulled my truck i heard a creaking noise. when they got me out i left and i hit about 65 mph my truck was shakeing. and before i would d0 65 it would ried smooth. and they put the rope on back right side above the tail pipe.
Mar 31, 2010 at 1:13 PM
HMAC300
  • 48,601 POSTS
you probably had some mud drop off and get on your wheel or driveshaft. check those.
Apr 2, 2010 at 7:09 PM
JOHNDEERE16
yea thanks i did that alot of mud was underneath my truck but i havent driven it since then so i dont know how it will run. and one more question to the guy that replied to my post. how big can i get tires before i have to get a lift?
Apr 12, 2010 at 11:52 AM
HMAC300
  • 48,601 POSTS
i'm not really sure on tire size before getting a lift. I just used to fix the things. But rmemeber if you put on larger tires everything will be amplified on the front end, so if you have a problem there it will be way worse. But if you do go to larger tires got to trucks tv.com or truck u .com an dlook at what they have done because you can pickup what they call a death wobble which makes yoru truck wobble all ovoer the place until you fix the front end by lifting it and adding larger stabilizing parts due to the larger tires.....
Apr 12, 2010 at 12:57 PM
