1999 Chevy S-10 Lost
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
NIGHTRUNNER
Had a problem with 99' s-10 6cyl: lost negative wire to fuel pump and replaced it, truck worked for 3 weeks and I hit a bump in the road and the truck died and would not re-fire. Towed to the house and verified all fuses are intact, the engine turns over the fuel pump does work but for some reason i have no gas getting to carb. any solutions???
Dec 6, 2009 at 7:49 AM
HMAC300
  • 48,601 POSTS
if you replacced the ground wire it may still not be grounding right. YOu should have 45 p.s.i. if you don't have at least 40 the truck won't run. Check the fuel filter or just replace it. Then check your fuel pressure.....
Dec 7, 2009 at 3:50 AM
