HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Fuel System
Fuel Pump
Fuse
1991 Chevy S-10 fuel pump and fuel pump fuses
BLUELARRY
MEMBER
1991 CHEVROLET S-10
Electrical problem
1991 Chevy S-10 6 cyl Two Wheel Drive Manual
were is the fuel pump located and were on the fuse box is the fuel fuse
Thursday, May 21st, 2009 AT 11:51 PM
JDL
MECHANIC
Hello, I'm not sure of the litre size of your engine? The info I looked at was for the 4.3L.
The electric pump is in the tank. The fuse shows to be ecm B fuse, 10 amp, in the fuse box.
Friday, May 22nd, 2009 AT 4:20 PM
BLUELARRY
MEMBER
My 1991 Chevy S-10 has a 2.8 L - thank you.
Friday, May 22nd, 2009 AT 6:55 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Fuse Content
1998 Chevy S-10 Fuse And Fuel Pump
I Got A 98 S-10 The Fuel Pump Works Some Times And Sometimes It Dont, The Pump Is Brand New So It Isnt That. I Got A Fuse Labeled Eng1 In...
Asked by
simply_low2
1 ANSWER
1998
CHEVROLET S-10
VIDEO
Fuel Pump Control Module Fuse Replacement
Instructional repair video
1987 Chevy S-10 Fuse Keeps Blowing Ecm
Truck Was Running Just Stopped. Thought It Was A Fuel Problem. Had The Module Under The Distributor Cap Check At Auto Zone. It Was Fine....
Asked by
omie
1 ANSWER
1987
CHEVROLET S-10
Priming But Not Pumping Fuel Pump
Bought A 89 Chevy S10, Changed The Fuel Pump, Then Drove It 25 Miles. Truck Would Not Start After Being Turned Off. Fuel Pump Sounded...
Asked by
tilldown
1989
CHEVROLET S-10
1997 Chevy S-10 Fuel Pump Problems
I Replaced The Fuel Pump And Now I Don't Have 12 Volts At The Pump. I Have Checked The Ecm Fuse And Can Hear The Fuel Pump Relay Come On...
Asked by
jsollars
1997
CHEVROLET S-10
1996 Chevy S-10 Fuel Pump
1996 Chevy S-10 Four Wheel Drive Automatic My Sons S10 He Just Put In A Brand New Fuel Pump But When He Goes To Start Truck. The...
Asked by
scott4462
1 ANSWER
1996
CHEVROLET S-10
VIEW MORE
How to Use a Test Light
Fuel Pump Replacement
How to fix an engine that wont start
