1999 Chevy S-10 Installing a Tachometer
12,400 MILES • 6 CYL • 2WD • AUTOMATIC
TCP
  • 5 POSTS
My son has a 1999 Chevy S-10 4.3L V6 and wants to add a tachometer, I do not see a standard coil (round type) and was wondering where I hook up the wire for the tachometer to receive the RPM information.
TCP
Grand Rapids, MI.
[img:4e52cd7c43]http://www.2carpros.com/forum/automotive_pictures/190976_Bens_S10_007_1.jpg[/img:4e52cd7c43]
May 16, 2008 at 6:46 AM
MASTERTECHTIM
  • 4,750 POSTS
grAB THE WHITE WIRE AT THE IGNITION MODULE
May 16, 2008 at 9:42 AM
TCP
  • 5 POSTS
[quote:323d933014="mastertechtim"]grAB THE WHITE WIRE AT THE IGNITION MODULE[/quote:323d933014]
I attached to the WHITE wire of the plug on the ignition model this plug has a 2 wires on it a white one and a pinkish one.
I do get signal but it seems low, curb ideal in park 5-600 RPM's Cold.
There is another plug on the igition module with 4 wires going to it and this also has a white wire.
Any assistance would be helpful.
May 26, 2008 at 2:47 AM
MASTERTECHTIM
  • 4,750 POSTS
the white wire at the coil is the right one. make sure the setting on the tach is set correctly.
May 26, 2008 at 10:25 PM
TCP
  • 5 POSTS
Please see attached photo with the white arrow of where I attached the tachometer wire. I have verified that the tachometer is set to 6 cycl. Please give any advise on why I am reading low RPM's.
https://images.2carpros.com/forum/automotive_pictures/190976_Bens_S10_008_2.jpg
May 29, 2008 at 2:36 AM
MASTERTECHTIM
  • 4,750 POSTS
grab the white wire at the ignition module, its right next to the coil. let me know if that works ok
https://images.2carpros.com/forum/automotive_pictures/139033_coil_1.jpg
May 29, 2008 at 4:37 AM
TCP
  • 5 POSTS
I attached the wire from the Tachometer to the White wire (pin B).
Sunpro Tachometer reading the same RPM's at Curb ideal in Park 500-600.
Any Idea's ?
May 29, 2008 at 12:06 PM
