1983 Chevy S-10 tachometer
DJISPIMP
Engine Mechanical problem
1983 Chevy S-10 6 cyl Four Wheel Drive Automatic
how dio i install a tach in my truck
Dec 27, 2008 at 5:33 AM
MIKE H R
  • 3,094 POSTS
There is usually four wires comming from the tach . One is ground one for lights at night two to connect to the distributor wire. some tachs have 5 wires. check with the manufacture to get a diagram and see what wires are connected to each thing. Don't install with out knowing what wire go where if youy hook up the wrong wires then the tach can short out.
Dec 30, 2008 at 12:44 AM
