Hi, I had a heater hose start leaking today, its the one that come from the driver side, lower Rad hose. I replaced it and poured a little antifreeze in there, and thought I was done. Now the Heater will not blow warm air, and the truck will not heat up over 150. It usally ran alittle under 210. I had heat till today. The heater core isn't leaking. I took the cap off and let it run for an hour, I added more fluid, and it still never heated up. I put the cap back on and drove it around the block and it never got over 150 and the heater never blew hot air. I parked it and I took the rad. Cap off and it didn't spew coolant, it just sat there, Ive never saw this b-4. WHAT DO I NEED TO DO? Help! Thanks
SPONSORED LINKS
Saturday, October 3rd, 2020 AT 12:18 PM
(Merged)
