1999 Chevy S-10 Engine Start-up
ROBINONE
  • 1999 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 139,000 MILES
Vehicle will not start. Before this happened, vehicle was
running rough and was smoking ( Blue to white in color).
then it would smooth out and stop smoking. Any help
would be grateful. Rj
Monday, September 27th, 2010 AT 11:08 PM
I assumed its cranking over and will not start if so do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, September 27th, 2010 AT 11:44 PM
