1999 Chevy S-10 1999 S-10 2WD Pickup 4.3x will not start
PIANOLESSONSONLINE
  • 1999 CHEVROLET S-10
  • 6 CYL
  • 15,000 MILES
New Delco fuel pump 63 lb pressure. New fuel filter, new pressure regulator, new computer, new mass air flow, new plugs, wires, cap, rotor, cam shaft pos. Sensor, crank shaft pos. Sensor, EGR valve. New coil & module, air temp sensor, throtle body pos. Sensor.
The only time it will start is w hen I pour fuel into the throttle body. It will start, but quits when the fuel is gone.
What could it be?
Monday, June 1st, 2009 AT 8:28 PM
BILLYMAC
  • 2,204 POSTS
Hi. Wow you have spent some money on parts here. What I would do next is this. Remove the plantum under the plantum you will see the fuel injection control unit. These lines snap into the fuel ports replace this part. I can, t say that is what it is but it has to be ruled out. Good luck billymac
Monday, June 1st, 2009 AT 8:52 PM
