If the system is fully charged, compressor is staying engaged when ac is on max ac, and only warm air is blowing out of the vents, this may be complicated. Its not one side blowing cold and one side hot right? The compressor isnt engaging, and disengaging every 15 seconds or so on max ac right? Also, if you change your vents to different zones, do you have cold air comming out anywhere?
SPONSORED LINKS
Thursday, September 2nd, 2010 AT 10:33 PM
