Hello -
So I understand what you are saying... When you select high blower speed and hot temp control and floor - no hot air on floor but air comes out there....... If you select vents..... Air comes out vents just not hot....... Same with defrost?
You have checked to make sure you have the correct coolant level..... At operating temperature you turned the heater on high and made sure the coolant was totally full.
Does the temperature of the engine coolant stay where it should be or has it changed at all?
At operating temperature you feel both heater hoses going in and coming out of the dash... Both are hot?
Wednesday, February 18th, 2009 AT 2:02 PM
