Engine Mechanical problem
1998 Chevy S-10 4 cyl Two Wheel Drive Manual
i have two valves that wont close all the way what can I do to get them to close propperly with out taking my head off?
Wednesday, January 27th, 2010 AT 5:34 PM
MECHANIC
What do you mean they won't close properly? Is there a broken valve spring? If not and the valve won't seal, you need to have the valves redone (ground) so they will seal.
