1995 Chevy S-10 4 wheel drive will not engauge
BECKH0421
  • 1995 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 103,900 MILES
Front wheel will not engauge
no current to front diff
Sunday, November 16th, 2008 AT 9:45 PM
SWILLIAMS
  • 597 POSTS
Check the vacuum lines to the front axle actuator (located near the battery). If you shift into 4X4 and don't have vacuum to the line on it then the problem is likely the vacuum switch on the transfer case. It isn't hard to change. If you do have vacuum then you will need to check the cable and the actuator fork itself for operation.
Monday, November 17th, 2008 AT 10:27 AM
