1995 Chevy S-10 How Can I Fix This!
SHE78SHA
  • 1995 CHEVROLET S-10
Brakes problem
1995 Chevy S-10 4 cyl Two Wheel Drive Automatic
Yes I have a question for you when I get into my truck and I go to hit the brakes all I hear is air and they are really hard to push and can barely stop how can I fix this or what would cause this?
Saturday, May 9th, 2009 AT 12:11 PM
MIKE H R
  • 3,094 POSTS
With the brakes hard to push and you hearing air, then I would check the vacuum lines going to the power brake booster. It is connected to the master cylinder. Check for leaks in the vacuum lines. If you find no problem with the lines then the problem would be with the booster itself. There are no maintance on the booster except for checking the vacuum lines
Saturday, May 9th, 2009 AT 12:19 PM
