I just changed the lower, driver side ball joint on my truck. The axle nut was so tight, I had to use a 3 ft extension on the ratchet to get the nut loose. Then an electric impact gun was enough to run it the rest of the way off. The ball joint replacement went well, and upon re-installation of the axle nut, it went on approximately 1/2" farther than it was before I had started. (I used the impact run to run it on). During a test ride, the ABS system activated while coming to a stop, during the last 10 feet of travel. Neither the ABS, or brake lights light up while this happened. Any suggestions?
Sunday, May 3rd, 2009 AT 1:15 PM
